Transmissions
Transmissions
Hello, I have a 1999 ram 1500, it has the 5.2 magnum and the 46re transmission in it. I bought the truck with a rebuilt transmission. Not long after I bought it, it blew cooler lines to the transmission. While replacing them, I cracked the housing where the fitting goes in. I pulled a transmission from my local junk yard but it didn’t work, however the case is good. I’m not experienced in automatic transmissions and I do not have the money to pay to have it rebuilt nor the money to buy a reman. I was considering swapping a manual into it, I’ve rebuilt several manuals and I know how they work. What transmission do I need, what ECM would I need or would I have to replace the one in the truck, how hard would it be, should I just try and rebuild the automatic myself? Thanks in advance for any help.
Now if you are like me and just like manuals more here is what you will need. A NV3500 from a 1500 truck asking with the front driveshaft and obviously the pedals, shifter, manual crank sensor, and the center console with the boots. You don't have to change the computer you will just have a check engine light and you can also buy a manual tune if the light bothers you.
