1995 Dodge Ram 1500 5.9 code 24
Old Apr 28, 2021 | 04:29 PM
chrisfox5045@gmail.com's Avatar
Default 1995 Dodge Ram 1500 5.9 code 24
Replaced tps and checked all wire voltage and ground still gettting code 24 and truck stalling when letting off gas going slow. Plus sporadic trans shift. Only other code is o2 sensor. Ideas? 1995 5.9
Old Apr 28, 2021 | 05:08 PM
DerTruck's Avatar
DerTruck
Did you test the TPS as described in the service manual, back probing the sensor output ? More than 200 mV at idle and less than 4.8V at WOT ? Might want to jiggle the throttle blades a bit at off throttle.
Old Apr 28, 2021 | 05:24 PM
I did the last tps like that and nothing changed so I figured it was the tps and bought a new one. Haven’t tested it yet thi
Old Apr 29, 2021 | 06:26 AM
Moparite's Avatar
Moparite
Did you clear the code after you replaced it? If not clear it and test the return voltage the pcm is getting. Code is for an over voltage going back to the pcm.
