Battery Ground Wire
Old May 3, 2021 | 08:26 AM
93 ragtop's Avatar
93 ragtop
Default Battery Ground Wire
I have a 2000 ram, 5.9 gas engine I am putting in a 87 dakota.
Could someone tell me specifically where the battery ground is connected to the engine?
Thanks
Old May 3, 2021 | 10:59 AM
Ramman18's Avatar
Ramman18
On my 318 it connects to the top power steering pump bracket.
Old May 3, 2021 | 11:58 AM
ol' grouch's Avatar
ol' grouch
Thanks
Since it's a custom install, you can mount it where you like it. Functionally, you will want a large ground cable to the battery to bolt to the block somewhere. This is the main ground. I would also run a couple of smaller grounds,usually mesh straps, from the firewall to the engine. These will complete the body ground circuit. You have a small wire hooked to the negative cable but these will supplement it. If it gets damaged, these will keep your lights, radio, HVAC and other systems working properly.
Old May 8, 2021 | 07:23 PM
93 ragtop's Avatar
93 ragtop
Thank you for your response. I pulled the motor out in october, and just assumed it bolted direct to the block or head.... But there are no spare holes in the front or side.
Can you tell me, is it one of the 4 mounting bolts that hold the bracket to the engine?
And thanks for your help.
Old May 8, 2021 | 07:25 PM
93 ragtop's Avatar
93 ragtop
Thanks for your response. Yes, I have a ground strap from the back of the passenger head to the firewall.
Old May 8, 2021 | 10:52 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
There are two bolts that hold the bracket to the engine. It's the top one
