Coolant leak 98 ram 1500 5.2l
Old May 18, 2021 | 03:31 PM
John Carter's Avatar
John Carter
Default Coolant leak 98 ram 1500 5.2l
So recently I have replaced my water pump, thermostat, hoses, thermostat housing and all the gaskets everything has been tightened even used gasket sealant on the gaskets. But yet I still have a coolant leak coming from the top and only reason I know it's at the top is there's coolant pooled up by the housing. I'm not sure what's causing it ibe replaced the thermostat housing gasket 3 times now and it still leaks.
Old May 18, 2021 | 03:36 PM
Bypass hose between the pump, and the intake manifold.
