Vacuum issues
Old Jul 26, 2021 | 03:23 PM
Pgriff's Avatar
Pgriff
Default Vacuum issues
I have a 2001 dodge ram sport 4x4. Everything that's vacuum operated does not work, the 4 wheel drive will not engage the cruise control and the vents are not working. The only thing that still works is the power brakes. Any help would be greatly appreciated
Old Jul 26, 2021 | 04:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You need to visually inspect the vacuum lines. The vents vacuum line goes in right by the AC lines. The 4wd see if you are getting vacuum on one of the lines. Cruise line goes in under the battery tray check to see if it's broke.
Old Jul 26, 2021 | 06:09 PM
Spillage's Avatar
Spillage
+1 on a visual inspection.
The line that goes through the firewall with the A/C lines is a classic place for chafing a hole, if not completely severing it.
Old Jul 26, 2021 | 08:18 PM
Pgriff's Avatar
Pgriff
Thanks for the info, I'll double check all the lines.
Old Jul 26, 2021 | 09:14 PM
There may be check valves installed in some of the lines, make sure they are installed in the correct direction.
