What is this?
Old Aug 3, 2021 | 11:58 AM
Dhalas818's Avatar
Dhalas818
Default What is this?
Replaced both my yellow stock headlights with a pair of Spyder lights and noticed this plug and harness and have no idea what it's for...educate me!
Old Aug 3, 2021 | 12:19 PM
Maybe for fog lights.
Old Aug 3, 2021 | 12:27 PM
Dhalas818's Avatar
Dhalas818
My truck is a 2001 and didn't come with fog lights. Wonder if the harness was in all trucks as an option. Not sure.
Old Aug 3, 2021 | 02:10 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
My truck with fogs has that harness. Can't find it in the diagrams I think it's just there lol. There is one behind each headlight
Old Aug 6, 2021 | 03:52 PM
J D GA's Avatar
J D GA
Default Ground Joint
Long story short, while routing a salvaged harness, I determined that's a ground joint (cluster) .
Ground Joint example
Long story LONG, have an '01 also without factory fog lights. My dad gave me the fog light harness from a Nissan and the actual lights off another Ram. I kept reading that there is wiring for fog lights on our trucks even if there are no lights installed. Try as I might, never located it so I used what came off the Nissan. I went to a local junkyard and got the headlight/fog light switch off either a Durango or Dakota. Ran only 1 new wire from that thru the firewall to connect to a relay on the salvaged fog light harness. Best I recall, I put a jumper wire inside the relay so fogs stay on with high beams; we live in a rural area where deer abound & I don't want a hoof or rack in my face.
