Issues
Old Aug 18, 2021 | 06:26 PM
Laurens Moja's Avatar
Laurens Moja
What brand?
NPK if i'm correct
Old Aug 18, 2021 | 06:28 PM
Probably NTK, but, those should be good.
Might try running some combustion chamber cleaner thru it? (fuel additive)
Old Aug 18, 2021 | 06:34 PM
Laurens Moja
​​​​​​I'll try to go get some tomorrow.
already ran a bottle of injection cleaner through it , as i thought at first it was an fuel injection problem.
The wierd thing is, it drives 1000x better on LPG ( liquefied petroleum gas ).
Old Aug 18, 2021 | 06:36 PM
Are you running on gasoline now?
Old Aug 18, 2021 | 06:45 PM
Laurens Moja
Yes all my issues are gasoline related. On LPG it seems to drive way better. Doesn't backfire at all..
Old Aug 18, 2021 | 06:51 PM
What possessed you to go back to gas?? I would be real tempted to put the LPG stuff back.
Old Aug 18, 2021 | 06:58 PM
Laurens Moja
The LPG is still installed , and working. ( Well it did until my magnetic valve broke, repair on it's way )..
The issue is that i need to have correct readings CO% and o2 sens on both fuel types to be approved on the road. Especially gasoline needs to be right , as it's a gasoline car from the manufacturer..
Old Aug 18, 2021 | 07:30 PM
Ah. Ok. That makes sense.
Have a read here about High CO readings.
Old Aug 19, 2021 | 11:28 PM
Laurens Moja
I'll check my airfilter tomorrow
And maybe order new probes? Would you suggest to?!
I've added co cleaner additive to the fuel now , we'll see what that does..
btw, if it would have cracked heads, wouldn't the car always run bad?
​​​​​​As it's sometimes working good and sometimes not, i can't imagine it's something mechanical..
Old Aug 20, 2021 | 12:03 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
My cracked heads only used a little oil and coolant. Truck ran great though.
