Electrical port connections?
Old Aug 23, 2021 | 11:37 AM
Steven Jones's Avatar
Steven Jones
Default Electrical port connections?
Hey guys, been doing a lot of work on the underside of the truck recently Noticed a couple of electrical connectors are unplugged
This one is directly underneath the fan shroud I have no idea whats supposed to connect to it and i didnt see any loose plugs near it
These ones are right near the horn/power steering servo and washer fluid reservoir They are both sets of two connected to each other One i know goes to the washer fluid because i unhooked it doing the plenum but never put it back But when i put it back today the washer fluid still doesnt work The other three i have absolutely no idea One of them looks like its on the same wire as the one thats plugged into my power steering servo Also my power steering doesnt work
Old Aug 23, 2021 | 11:39 AM
Steven Jones
Sorry for such a long post But evrything is connected to my ps servo no vac leaks but the servo definitely looks like it was eaten by battery acid
Also when i replace the power steering sevo is there anything yall did to protect it from corrosion from battery acid?
Old Aug 23, 2021 | 03:58 PM
Cruise servo? Could put something over it, piece of sheetmetal or some such, to re-direct any stuff coming from the battery.
The one directly under the fan shroud is likely for fog lights.
Old Aug 23, 2021 | 07:22 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
HeyYou is right it's where the fog light harness connects, the other one can you get me a better picture? What color is the wire
MoparFanatic21
Nvm that other one is what looks to be the temp sensor for the overhead console
