2001 1500 fuel pump
Old Sep 12, 2021 | 11:11 PM
2bit's Avatar
2bit
Default 2001 1500 fuel pump
I just bought a 2001 1500 V8 that doesn't run. If I trickle some gas into the throttle body, it will run. I can't hear the fuel pump run. I looked in the fuse panel by the driver's door and the distribution center under the hood. I can't find a fuse for the fuel pump. I switched the fuel pump relay with the horn relay. The horn works with both relays. Is there a fuse somewhere, or fusible link? Can I power the fuel pump from the relay terminals to test it?
Old Sep 13, 2021 | 12:01 AM
DerTruck's Avatar
DerTruck
The load side (power to the fuel pump) has a 20A fuse in location 3 in the PDC. The control side has a 10A fuse in location 9 in the inside fuse panel.
Wiring diagrams and other service info here .
Old Sep 13, 2021 | 12:17 AM
2bit's Avatar
2bit
Thank you, I'll check them tomorrow.
Old Sep 13, 2021 | 06:06 PM
DerTruck's Avatar
DerTruck
Regarding running the fuel pump without the relay you can jump pin 30 and 87 at the socket. The pump should run even with the ignition off.
Old Sep 13, 2021 | 10:17 PM
2bit's Avatar
2bit
Thanks, I couldn't find any bad fuses. I'll just tow it home and try jumping it when I have time. I probably should just order a fuel pump. I appreciate your help.
