Fuel injector
Old Oct 2, 2021 | 09:16 AM
Shavis's Avatar
Shavis
New Member
Default Fuel injector
Is there a way of removing and cleaning my fuel injector on a 5.9
Old Oct 2, 2021 | 10:29 AM
Yeah, they come out fairly easy, but, you need some fairly specialized equipment to clean 'em. You could probably make something up...... if you have the skills/stuff layin' about. Or, you could send them out to have them cleaned/flow matched, or, you could just replace them.
Old Oct 2, 2021 | 06:11 PM
Shavis's Avatar
Shavis
New Member
Would I have to remove the fuel rail
Old Oct 2, 2021 | 06:45 PM
AtomicDog's Avatar
AtomicDog
Yes. The fuel rail holds the injectors down from the top, as the rails are bolted to the intake manifold.
Old Oct 3, 2021 | 09:45 AM
Moparite's Avatar
Moparite
Make sure you clean all the dirt/debris away from them, If not it will fall into the injector hole.
