P0382 Engine Code
Hi Guys,
I'm kinda new to this forum, thanks for the add.
So I have a 2000 Ram 2500 4WD, I am getting a P0392 code, first I checked if all the wires were plugged in and they were. Then I replaced the solenoid set, rechecked the wires cleared the code and it instantly shows the code again. Next I checked the grounds on the small terminals they checked good going to ground also. I also removed the two small terminal grounds and made a new wire set to directly ground them, cleared the codes and the P0382 again instantly re-appears. So I guess it can be one of two things, either the plus side of the small terminals have a break or short in them or the ECU is malfunctioning.
I could really use some advice.
TIA
TIA
