01 Ram 5.2 O2 sensor codes
Old Nov 27, 2021 | 08:08 PM
Rich427's Avatar
Rich427
Default 01 Ram 5.2 O2 sensor codes
01 ram 5.2 throwing P0031 and P0037 CEL was going on and off for a few days now it’s been consistently on the past few days. Is it likely both sensors would be bad? Thanks
Old Nov 27, 2021 | 08:49 PM
DerTruck's Avatar
DerTruck
Unlikely, the codes are actually for the heater circuit so it could be an issue with the heater supply voltage. Check the dark green/white wire at the oxygen sensor *connector* for 12V and while you're down there check the resistance across the heater to the brown/white wire. Should be very low sub 20 Ohms. Note that the wires from the connector to the actual sensor have different colors so look up at the connector.
