Trans codes trigger BRAKE and ABS lights?
Old Jan 8, 2022 | 04:26 PM
Keith_L's Avatar
Keith_L
Default Trans codes trigger BRAKE and ABS lights?
I just pulled this '98 into the shop. One thing I was curious about was the BRAKE and ABS lights of which these trucks are so fond as they were both on full-time.
I was also curious if my Autel MD808 could read anything ABS related (apparently it can't) so I just went into general ECM codes. It reflected one stored (not pending) code even though I was not getting an actual CEL.
Now dammit I had either a P0750 or P0751 -- I wish I had paid closer attention -- but it did say Shift Solenoid A which should be 0750 but I swear it was a 751
Anyway, once I cleared the code both BRAKE and ABS lights went off. Normal? Am I hallucinating? Neither? Both?
Old Jan 8, 2022 | 08:14 PM
Take it for a drive, use the brakes hard. Make sure abs kicks in. See if the lights come back on.
So far as I know, those codes won't have anything to do with abs...... But, it's a dodge. So, ya just never know.
Old Jan 9, 2022 | 06:55 AM
95RAM360's Avatar
95RAM360
I got that code when my rear pumpkin speed sensor wires got melted from my exhaust (not stock) repaired 6 inches of wire, no codes no more lights
