powerlocks broken
Old Dec 30, 2005 | 09:59 PM
beingdevious's Avatar
beingdevious
Default powerlocks broken
i bought a used 2000 1500 and the power locks dont work in it. i have taken the door panel off and used a volt meter on the connector plug.
when i press the button up (to the unlock position) i get a reading of +12
when its stationary in the middle it reads -12
when i press the button down (to the lock position) i get a reading of 0
same occurs on the passenger side switch
im thinking the owner before had a remote start or alarm system, and removed it when he sold it. has anyone had this happen? and any ideas on how to fix this? possoibly a wiring diagram on the lock system?
ive checked all the fuses in the side panel in the dirvers side door. nothing wrong there.
im confused, and i just want my locks to work
possibly email me at beingdevious at gmail dot com since i dont check this forum much...
Old Dec 31, 2005 | 11:29 AM
bamory's Avatar
bamory
Default RE: powerlocks broken
I had a aftermarket remote start/entry crap on mine, i took it all off, and when doing so I had to cut some existing wires that was tapped into that system, while i was putting it back together I experienced the same thing, your problem will probably lie under the the panel directly below the steering wheel, before u go in and start looking around, get a wiring diagram, look for the wires that feed the power door lock relay in that panel i mentioned above. If you are not savvy at this you can always take it to someone who installs those start/remotes, ask them to take a look and see if someone had one installed and If there is anything not put back together, they usually only charge a small amount of $$$$, I took my daughter toyota in and had them look at hers, only because I couldnt find a diagram
Old Dec 31, 2005 | 04:10 PM
beingdevious
ok, the only thing i can fine is 3 cut wires. but i know exactly what they are. theres a 2 guage power supply line for an amp, the RCA line, and the remote blue wire. i cant find anything else cut. i did manage to get ahold of a wiring diagram. [thanks btw to tech_john on another forum] i just have yet to look at it.
Old Jan 1, 2006 | 12:10 AM
sal mosca's Avatar
sal mosca
Did you ever figure it out? Mine keeps acting up. It works then it doesn't and back and forth.
E-mail me at salmosca@verizon.net.
Old Jan 1, 2006 | 05:33 PM
beingdevious
im gonna take it all apart tomorrow evening and compare to the diagrams. im out of town right now, but ill let you all know what i find out..
-AJ
