Fuel injector connector issues
Old Feb 14, 2022 | 11:23 AM
Rainman64's Avatar
Rainman64
Default Fuel injector connector issues
2000 Ram 2500 V10.
Didn't drive for about 6 months.
I went to start it and it was throwing CEL
Ran diagnostics, AIT sensor and P0205.
Look under the hood, and a damn field mouse built a nest in the engine.
Chewed through the AIT sensor wire and #5 injector connector wire.
Partially chewed through #3.
No problem, order new connectors through RockAuto.
So I cut off injector #3 connector, and put in the new connectors.
Temp connect the wires to see if it clears the codes.
AIT is good now, but it now throws codes for #5 and #3.
I will take a DVOM to it as soon as we get some decent weather, but could there be an issue with the new connectors?
Seems odd that #3 was fine with a partially chewed wire, but with a new connector it is coding P0203....
Old Feb 14, 2022 | 11:35 AM
master tech's Avatar
master tech
Site Moderator & Tech
You may need to replace the injectors. But I would put fuel cleaner in the fuel tank and hope it cleans the tips of the injectors.
Old Feb 15, 2022 | 05:48 AM
Moparite's Avatar
Moparite
You need to clear the codes it won't go away by itself.
