46RE late shift after overhaul
Old Mar 1, 2022 | 12:00 PM
MrLantz's Avatar
MrLantz
Okay, so I think I'm getting closer to something...
The truck seems to run fine as long as it's cold. As soon as it gets up to working temp the problems start occuring again. I was just out on a test drive and after about 10-12 minutes it started clinging to gears, jump out of gears and the whirring/whining noise started coming back. This time I had the opportunity to climb under the truck and could locate the noise most likely coming from the torque converter. I have no idea why.
I unplugged the 8-pin connector in the transmission, essentialy making the transmission obey my commands, and took off again in manual 1st. I shifted through 1-2-3 with no real difference, it seems to slip out of gear anyway. This of course generated a check engine light which I've never had before. BUT, when I plugged it back in and restarted the car it stayed on. I grabbed my reader and found 2 codes: P0753 (Shift Solenoid A Electrical, which I believe has to do with gear 3-4) and P1763 (which I believe is governor pressure sensor).
As to why my torque converter is making noise I really don't know. Could this be at all related to my codes?
Old Mar 1, 2022 | 12:44 PM
AtomicDog's Avatar
AtomicDog
May not be related, but, have you removed/bypassed the check valve in your transmission cooler line to help your transmission stay cool? If not, please take a look at this thread on how to remove the check valve and bypass it - https://dodgeforum.com/forum/2nd-gen...46rh-46re.html
Old Mar 1, 2022 | 01:31 PM
MrLantz's Avatar
MrLantz
Thanks for your reply.
No, I have not removed or bypassed the check valve. It's also very unlikely the noise is due to overheating (the trans temp light would have come on, right?) since this was just a very short drive from cold start in very cold weather. It does however seem like heat is a factor since that's when my problems start.. But overheating feels unlikely.
Old Mar 1, 2022 | 02:22 PM
MrLantz's Avatar
MrLantz
I'm thinking I might as well order some stuff, but I'm unsure about the solenoids/transducers.
The things I'm looking to order are:
1 x Borg-Warner Governor pressure sensor
1 x Governor pressure transducer
1 x Governor body gasket
1 x 3-4 accumulator spring
1 x Lock-up and OD solenoid with harness
This should sort out the P1763 code
What I'm confused about is if I'm supposed to get a 3-4 shift solenoid also? (for the P0753 code). Or is it the same as the Lock-up and OD solenoid?
Old Mar 1, 2022 | 02:30 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Understand. Just wanted to mention it, since it has caused many folks issues with their transmissions. It's something to keep in mind to do as you perform other transmission maintenance/repairs.
Old Mar 1, 2022 | 02:33 PM
You have mechanical issues in the trans. If it still screws up with the electronics disabled (and yes, that WILL set those codes), its rebuild time. Probably something from when the snap ring broke made its way thru the trans, and that was the beginning of the end.
Old Mar 1, 2022 | 03:13 PM
MrLantz's Avatar
MrLantz
Not trying to be naive here, but what about it working perfectly when cold? A mechanical issue would surely always be there regardless of hot/cold trans.
Also, we found both pieces of the snap ring intact when removing everything and could form a complete snap ring with the pieces.
Old Mar 1, 2022 | 03:41 PM
With the 8 pin connector unplugged, the electronics no longer play any role in the transmissions function. Something is getting warm, and failing internally. Pressure is bleeding off somewhere. Finding it is the fun part.
Old Mar 1, 2022 | 04:02 PM
MrLantz's Avatar
MrLantz
Thank you for your reply.
I agree it seems like it's loosing pressure.
Would you have any idea of what could have caused this doing what the workshop did? Everything worked perfectly before, and the truck only has 11000 miles on it.. I'm not really ready to pay for a complete rebuild atm.
Old Mar 1, 2022 | 09:30 PM
Unfortunately, the inner workings of automatic transmissions are black magic so far as I am concerned. You spin one end, and it might come out the other end, faster, slower, or even the opposite direction. What happens in between there? That's the magic. I can do basic troubleshooting, but, beyond that, I am just guessing. I suspect though, that it isn't a result of what the shop did, more than likely, its a result of why you took it to the shop in the first place. It was gonna happen anyway.... regardless of if it went to the shop. Probably wouldn't hurt to drop the pan, and see if you find anything interesting......
