How to tell 42 from 46 RH transmission
Old Mar 17, 2022 | 09:55 PM
DamRam95's Avatar
DamRam95
Default How to tell 42 from 46 RH transmission
How to determine which transmission I have in my 1995 Ram 1500 with a 5.9 l engine. The number on the side of the transmission is PK521191722348 9857.
I'm trying to get the rebuild kit for it but they list a kit for a 42RH and a 46RH transmission.
I know it's an RH due to it having a 3 pin connector for the control harness on the drivers side.
Any help would be appreciated.
Old Mar 17, 2022 | 09:58 PM
95RAM360's Avatar
95RAM360
It’s a 46rh……the 42 I think was for dakotas
Old Mar 18, 2022 | 12:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
Thats easy. The 42/44 RH/RE transmission have a square pan and the 46RH/RE have a square plus a hump on the corner on the pan.
Old Mar 18, 2022 | 06:22 PM
DamRam95's Avatar
DamRam95
Thank You both, Master Tech and 95Ram360.
The information Master Tech gave enabled me to verify what 95Ram360 said was correct. Thank You both again.
