P1756 code I think
Old Mar 19, 2022 | 01:56 AM
CheeseWheel's Avatar
CheeseWheel
Default P1756 code I think
I cleared the code and wrote it down but can’t find the note for it. Anyways the description was the governor pressure was either below or above target consistently target psi 15-20psi. Not sure why I’m getting the code. It isn’t the solenoid or sensor. I’m on my second pair and still having issues. Someone please help! Connector appears fine, wires aren’t frayed or expose.
I should also note that it takes several days for the code to come back, but it has come back 3 times.
Old Mar 19, 2022 | 05:48 AM
Moparite's Avatar
Moparite
P1756 Governor Pressure Not Equal to Target @ 15-20 PSI
How did you clear the code? Might want to get a scanner that reads live data to see what the pcm is seeing pressure wise. Also can do a pressure test on the trans.
Old Mar 19, 2022 | 10:27 PM
CheeseWheel
yeah I think I’m Gonna have to look Into getting a live scanner
Old Mar 20, 2022 | 09:47 PM
95RAM360's Avatar
95RAM360
Wiring may look good but that don’t mean anything….hot temps can kill wiring quick…but get the kit that comes with electrical harness I thing the borg one is like $170
