Engine ticking noise
Old Mar 31, 2022 | 12:42 PM
HD Kowboi's Avatar
HD Kowboi
Default Engine ticking noise
I recently noticed a ticking noise that seems to be coming from the drivers side of the engine. It seems to go away in a minute or less, I'm wondering if it might be a lifter. If so, how do I diagnose it for sure. I have 2001 3.9l with about 75,000 on the engine. Thanks for your input.
Old Mar 31, 2022 | 02:12 PM
Probably a lifter bleeding down when it sits. Or, possibly and exhaust leak?
Old Apr 1, 2022 | 01:01 PM
HD Kowboi's Avatar
HD Kowboi
I already checked the header bolts and exhaust flange bolts. I do have a small exhaust leak but it's on the back side of the cat, it needs to be welded. I didn't think that would cause the ticking, it goes away after about 15 or 20 seconds.
Old Apr 1, 2022 | 01:58 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sounds like an exhaust or lifter. As the exhaust heats up it will close and small gaps and the lifter will pump up.
Old Apr 1, 2022 | 02:34 PM
true blue's Avatar
true blue
It could also be the purge solenoid. Unplug it n see if the noise goes away, or just stethoscope it.
