2001 3500 4wh dr clutch issues
Old Apr 5, 2022 | 07:03 PM
rwj54's Avatar
rwj54
Default 2001 3500 4wh dr clutch issues
my hydraulic clutch pedal goes all the way to floor with no resistance. If I wait 2or3 minutes I get pressure but as soon as I depress pedal, all goes soft again,, if driving say in second,, I can depress the pedal to get it out of 2nd,, but no pressure to go to 3rd without it running I can use all the gears. master or slave cylinder? I see no leaks nor can I see any way to bleed either cylinder. Are those my problems, and are they installed as one unit? Thanks
Old Apr 5, 2022 | 09:33 PM
It's one or the other... hard tellin' which one, if there are no leaks. Not sure if you can buy the pieces individually, or if it comes as an assembly. Call your local parts store, and ask 'em. I suspect, the only way to figger out which one it is, is to replace one, and see if it fixes it..... I think, if it is available is the full, pre-bled, assembly, that would end up being the way to go.
Moving this to second gen ram section for ya. Welcome to DF!
