Is this only on start up? Does it do this after it has been driven? Mine does this after sitting for a week or more. The converter drains back, even with when it had the check valve. Put it in neutral for a couple minutes first then go to gear. These transmissions don't flow fluid in park stock. Also how is the fluid level when hot?
It has the same issue, warm or cold. It is particularly worse after sitting for a few months but even after being driven for a while and everything nice and warm it will still do this at startup.
