Check Gages Light
Old Apr 20, 2022 | 11:05 AM
CombatWombat's Avatar
CombatWombat
Red face Check Gages Light
I have a 1999 RAM 1500 with the 5.9l Magnum. Only 105k miles on it. Recently whenever braking, and even more recently when coasting and idle, the "Check Gages" light illuminates and the oil pressure gage drops to 0 for two seconds before returning to normal. I have replaced the Oil Pressure switch, and this seemed to have fixed the issue temporarily ( a few hours) but the issue returned. The oil levels are good, and I cannot seem to find anything on this issue. Dealership techs think that it might be a wiring issue. Before I have to pay for them to dig into it, I was wondering if anyone had experienced this issue? Thanks!
Old Apr 20, 2022 | 11:09 AM
Keith_L's Avatar
Keith_L
I'd get an actual op gauge on it. Coasting and idle is when pressure would be the lowest
Old Apr 20, 2022 | 11:11 AM
CombatWombat
Would an actual Oil Pressure gage fix the issue you think?
Old Apr 20, 2022 | 11:28 AM
DerTruck's Avatar
DerTruck
A mechanical gauge will tell if the pressure really drops at idle or if it's a problem with something on the electronic side.
Old Apr 20, 2022 | 12:24 PM
Keith_L's Avatar
Keith_L
You want a true, direct reading of op simply for diagnostic purposes.
Any shop could just yank your sender and thread in a gauge like a Snappy EEPV508/507 or an OTC 5610 or you could just buy an inexpensive mechanical gauge at your FLAPS and temporarily (or permanently) plumb it in and check for yourself. On my old '90 Bronco I put a mechanical op gauge in an a-pillar pod and really enjoyed the feedback and instantaneous response time (Ford is particularly bad about op gauges that LOOK like a gauge but are really just an idiot light)
You can typically plumb in an aftermarket mechanical gauge and keep the stock sending unit just using a tee and basic NPT parts from any hardware store plumbing section.
Or perhaps the Magnums have a nice unused port somewhere (I don't know)?
Old Apr 20, 2022 | 11:13 PM
95RAM360's Avatar
95RAM360
Have you checked the oil? Mine did this when when coming to slow down on a downward hill going to work, oil pressure dropped and check gauges came on (I have a 02 3rd gen ram but mines still the 5.9l)
checked oil, and nothing on dipstick, found a wear hole in timing cover and due to the low oil it took out a couple lifters…which I’ve since fixed
