Vibration/shudder at idle?
Old Apr 22, 2022 | 12:28 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
Originally Posted by Liddlez
Yes, I did.
Is the new IAC aftermarket or a Mopar replacement part? There have been issues with aftermarket IACs not functioning properly out of the box.
Also, have you scanned the PCM with a OBD2 scanner? Any stored or pending codes present?
Old Apr 22, 2022 | 01:02 PM
Liddlez's Avatar
Liddlez
Mopar, new. Functioning properly. The only code I have is a P0441 which I’ve tried to locate, but haven’t been successful. The lines are intact, the solenoid, and canisters are new. I’ve replaced them twice.
Old Apr 22, 2022 | 02:53 PM
The lines dry out and crack, and it isn't obvious...... Gotta do a pretty close inspection, or a smoke test to verify the lines are good.
Old Apr 22, 2022 | 02:56 PM
Liddlez's Avatar
Liddlez
I did. Trust me when I say I’ve ran every test available. Right now I’m going to replace the crankshaft position sensor with a mopar branded one. The last one was a “Holstein” aftermarket sensor.
Old Apr 22, 2022 | 02:58 PM
Named after a Cow?????? Oh, yeah, that's confidence inspiring.
Old Apr 23, 2022 | 07:49 AM
Moparite's Avatar
Moparite
P0441 Evap Purge Flow Monitor
Have you cleared the code? If so does it come back? You may want to go into more detail of what the "Vibration/shudder" is. My thoughts are if it acts like it's not running on all 8 cylinders it's most likely an ignition related problem. A vac leak will cause the engine to raise the rpm(not considered a " Vibration/shudder". Did you happen to check the vac hose coming off the throttle body that supplies vac for the evap system?
Old Apr 23, 2022 | 08:00 AM
Liddlez's Avatar
Liddlez
I’ve cleared that code like 10x and it returns. However, I think I solved the issue. The new valves were defective. I installed a mopar one, and it hasn’t came back. The thing is, the RPM’s do not bounce at all, and it’s mainly in the front end. I personally believe it’s a mechanical issue such as a fan blade out of balance or something.
Old Apr 24, 2022 | 08:10 AM
Moparite's Avatar
Moparite
You can take the belt off and see if it's still there. Also look at the balancer, The outer ring tends to move when the rubber deteriorates. But i don't think that would cause the issue you are explaining.
