Loss of low end power..
Old May 3, 2022 | 06:03 AM
95RAM360's Avatar
95RAM360
Originally Posted by KameronG7
Yeah I've had it scanned and the only 3 codes I got were p0500, p0135, and p1595
same code as mine, the p0500……I’ve replaced sensor and wiring (new exhaust melted wiring) and still have the code but I used thicker wire cuz that’s all I had at time…..I’d take a look into the speed sensor on your rear diff
Old May 3, 2022 | 09:12 AM
KameronG7's Avatar
KameronG7
How many different speed sensors are there? Cause I've replaced the output one already
Old May 3, 2022 | 09:51 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
Should be just one for that year truck on the differential. You could have gotten a bad/defective sensor or you may have a wiring issue. Addressing the issues behind each of those codes should get your truck performing the way it should again.
Old May 3, 2022 | 10:33 AM
KameronG7's Avatar
KameronG7
​​​​​​ Alright I'll get them figured out then have it scanned again
Old May 3, 2022 | 10:37 AM
KameronG7's Avatar
KameronG7
The only ones I've seen are on the transmission, which one is on the differential?
Old May 3, 2022 | 11:46 AM
AtomicDog's Avatar
AtomicDog
Oops, sorry - there are two. One on the transmission and one on top of the rear differential. Check both of those sensors and their wiring. You are also getting another code that points to the brake switch at the pedal seems to be faulty (or wiring), in addition to an O2 sensor being bad (or the wiring/relay that controls the heater of the O2 sensor).
Old May 3, 2022 | 11:50 AM
KameronG7's Avatar
KameronG7
brake switch at the pedal? How do I check that?
Old May 3, 2022 | 12:05 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Check this link for starters - https://www.engine-codes.com/p1595_dodge.html
Old May 4, 2022 | 04:48 PM
95RAM360's Avatar
95RAM360
I replaced mine with a mopar oem speed sensor (on the diff) plus I re did wiring to connector to where harness goes behind fuel tank (like 20” of wire) but all I had was a thicker gauge wire so I used that…..check engine light is off, Speedo works perfectly, but when doing the key dance trick I still get a stored p0500 code. But again Engine light is OFF…..
I said screw it, it’s got new parts, it’s working, and the times she starts in 2nd I turn truck off and right back on and first gear is there with no issues. I’ve had the start in 2nd gear happen maybe 8 times total…also my truck is a 2002 (3rd gen) so I don’t know if wiring is different….I do have the 5.9l 46re and Chrysler 9.25 rear diff with 3.55 lsd….so same running gear just not sure how my wiring matches to yours
Old May 4, 2022 | 05:02 PM
AtomicDog's Avatar
AtomicDog
Question
Could the issue you're having be the VSS sensor in the transmission possibly causing your issue?
