High pitch squeal around 4k rpm
Old Jun 4, 2022 | 07:57 AM
Moparite's Avatar
Moparite
the tensioner is working exactly as it should from what I can tell.
Pull the tentioner back and take off the belt, If the tentioner doesn't move back(spring tension) all the way then it my be starting to freeze up and not put full tension on the belt. When you have the belt off check the other components for possibly bad bearings.
