Ram 1500
Old May 29, 2022 | 03:03 PM
Slf84's Avatar
Slf84
Default Ram 1500
Just changed out transmission on my 98 ram 1500 2wd now all it does is die when I put it in any gear it starts right back up and no codes any help with this would be very appreciated
Old May 29, 2022 | 04:44 PM
Did you have the crank position sensor out of the way when you were doing the R&R on the trans? If it was still bolted to the motor, you likely damaged it.
Old Jun 3, 2022 | 04:33 PM
ZachW98's Avatar
ZachW98
I agree with @HeyYou . About half a year ago I swapped in a freshly remanned 47re from these guys, https://reman-transmission.com/trans...des/?code=47RE, and had a time with it after it was installed. Naturally, I thought it was a problem with the transmission and even called in to reman wanting a refund but after taking it to a different transmission shop they told me whoever installed it damaged my crank sensor. Not a bad fix but had a time trying to figure out what was wrong
Old Jun 4, 2022 | 07:47 AM
Moparite's Avatar
Moparite
Worth checking the crank sensor but sounds like it's something else. What year trans did you put in and where did it come from?
Old Jun 4, 2022 | 08:08 AM
dodgetruck2's Avatar
dodgetruck2
not sure in what way its dying if it lurches and stalls I would suspect the torque converter is locked up or something similar inside the trans, as I say this I would a assume its and automatic but is it a manual by chance?
Next I'm with moparite, verify the year the trans is for, it seems like you cant stray more then a year or so away from your model year and have everything work correctly, have you tried giving the truck every so lightly on the throttle when shifting, I had a bad IAC and it would stall when shifting into gear, like I said LIGHTLY on the throttle, just enough that the pedal is controlling airflow not the IAC motor.
