Voltage regulator
Old Jun 5, 2022 | 01:09 PM
CowboyChewy's Avatar
CowboyChewy
Default Voltage regulator
Where do I find the voltage regulator on a 1999 dodge ram 1500 pickup
Old Jun 5, 2022 | 01:50 PM
AtomicDog's Avatar
AtomicDog
The voltage is regulated by the PCM.
Old Jun 5, 2022 | 09:14 PM
dodgetruck2's Avatar
dodgetruck2
X2, always good to verify your battery terminals are clean and the PCM power supply/ground is good, same with alternator, after that pretty much SOL, REMAN PCM or external voltage regulator, that is if your alternator bench tests good
Old Jun 5, 2022 | 09:22 PM
AtomicDog's Avatar
AtomicDog
Or, a used PCM. Match up the part number to the one on your truck. For that year, I believe you might also need to have the VIN in the PCM changed to match the VIN of your truck, but that would be it. I keep a couple on hand for my '96, as they are pretty much plug and play as long as I get the PCM with the right part number. The external voltage regulator option can be done, but does take some wiring and work.
