TPS/APPS plug repair
Old Jun 6, 2022 | 12:57 PM
sucker02's Avatar
sucker02
Default TPS/APPS plug repair
Where can I buy the male end of the TPS/APPS sensor...one end plugs into the TPA itself and the other end does not have a plug as it splices into the wireing harness....dealer says not available... for any info.
Old Jun 6, 2022 | 01:02 PM
What are you driving?
Old Jun 6, 2022 | 01:26 PM
sucker02's Avatar
sucker02
sorry, I thought my signature would show...I have a 2001 dodge 2500 5.9 Cummins.
Old Jun 6, 2022 | 01:53 PM
Probably gonna have to go on the used market..... Car-part.com can find you the right year trucks, then you just need to contact the yards that have 'em, and see if they will send you one.
Try these guys as well. (no idea how good they are.)
Old Jun 7, 2022 | 07:53 AM
dodgetruck2's Avatar
dodgetruck2
Can I ask what your issue is? Is the connector damaged?
It should be a standard deutsch connector, however the number slips my mind at the moment
If your having APPS issues it probably needs to be replaced, the Timbo apps is the new style APPS and comes with the jumper harness to convert to the deustch connector, you could just splice that in
Old Jun 7, 2022 | 01:54 PM
AtomicDog's Avatar
AtomicDog
Can someone please tell me what the acronyms APPS (other than an app on a smartphone) and TPA mean? Also, any photos of these would be helpful, too.
Old Jun 8, 2022 | 09:18 AM
APPS: Accelerator Pedal Position Sensor.
TPS: Throttle position sensor.
Old Jun 9, 2022 | 08:20 AM
dodgetruck2
I think the APPS labeling comes from the diesel world or more specifically Cummins
Old Jun 9, 2022 | 10:59 AM
Anything that does throttle-by-wire will have the APPS. So far as I know, none of the second gen trucks did that particular trick. Now, the diesel trucks may have one, or not, I don't know.
Old Jun 9, 2022 | 10:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
They did
