Will a nv3500 hook up to a 360 LA mopar motor?
Old Jun 7, 2022 | 11:10 PM
ThatRedRam's Avatar
ThatRedRam
Default Will a nv3500 hook up to a 360 LA mopar motor?
Im putting a mopar 360 LA in my 95 dodge ram and i was wondering if my nv3500 will hook up to it just fine. will the clutch and flywheel and all that be fine because its all for a 360 magnum. So will the nv3500 with a clutch, flywheel for a 360 magnum work on a mopar 360 motor just fine?
Old Jun 8, 2022 | 09:13 AM
I would go with the flywheel/clutch/pressure plate for an LA motor. The 360 is externally balanced, don't know if anything changed on the magnum, but, better safe than sorry.
Also, there is a reason the NV3500 never came behind a 360. If you are gentle with it, it should live for a while though.
