Speedometer doesnt work.
Old Jul 10, 2022 | 06:24 PM
Nick321's Avatar
Nick321
Default Speedometer doesnt work.
The speedometer use to work on and off until one day it hasn't come back. Today I finally got around to replacing both the transmission sensor and rear diff sensor and at first it started to move but i came to a stop and it hasn't moved since. Could there be stripped gears or something else that could be wrong other than sensors?
Old Jul 10, 2022 | 08:18 PM
What are you driving?
Old Jul 10, 2022 | 09:08 PM
Nick321's Avatar
Nick321
Its a 1995 dodge 1500 5.2 magnum.
Old Jul 10, 2022 | 10:02 PM
AtomicDog's Avatar
AtomicDog
If its a 2WD truck, check the gear in the transmission and the VSS (Vehicle Speed Sensor) that the gear plugs into. If its a 4WD truck, the VSS and gear are in the transfer case.
Old Jul 11, 2022 | 07:34 AM
Might just be the VSS is not installed properly. It has to be indexed properly for correct gear engagement. May also be stripped drive gear on trans output shaft. Should be able to see it with the VSS out.
