To tell if you have 2 or 4 wheel abs look on the hubs of front tires (on the knuckle) , do you see wires going to them? If so it’s 4 wheel, no wires it’s 2 wheel
Thank you. No wires so it's 2 wheel ABS. Any ideas on where to proceed next, I'm truly at a loss 🤔
This is what i found via google search(my service manual doesn't show the abs fault codes).
Code 35 - Open in left front or right rear wheel speed sensor circuit.
72 is for a ROM checksum error in the CAB(controller anti-lock brake)
36 no signal from rear sensor
ROM error I would lead towards an ECU failure which like mentioned you can't really troubleshoot anything else if the ECU itself is faulty, it could be the only issue
I will replace the ECU and get back to you all. Thanks for the help all those who have contributed.
