Ram 318 Surging
Old Aug 10, 2022 | 01:26 AM
99RamACD's Avatar
99RamACD
Default Ram 318 Surging
Hoping you guys can shed some light into this issue.
I have 99 Ram 318 with a erratic/spontaneous surging at highway speeds. It doesn’t always do it but more the most part it does after a certain point.
I have already replaced the TPS sensor twice with a Standard brand as well as the IAC. I do have the brake light switch as I read that could be the problem but my brake lights work just fine. I can’t seem to find a vacuum leak that I can hear or see.
No check engine light either.
Old Aug 10, 2022 | 07:19 AM
How much of an RPM change are you seeing?
Old Aug 10, 2022 | 10:23 AM
99RamACD's Avatar
99RamACD
I believe it’s like a 300-400 rpm jump.
Sometimes it does for a good 2-3mins consistent and then there’s times where it won’t do it for a whole 45min drive.
Old Aug 10, 2022 | 06:52 PM
That may be overdrive going in and out..... any codes?? Maybe a pending code? (won't turn on the lite.)
Old Aug 10, 2022 | 08:58 PM
99RamACD's Avatar
99RamACD
None whatsoever. Drives fine for the most part if I drive it locally or on short runs.
Old Aug 10, 2022 | 09:28 PM
Need to do some data logging, see what the pcm thinks is going on.
Old Aug 10, 2022 | 11:35 PM
99RamACD's Avatar
99RamACD
Gotcha. That’s something I would’ve like to avoid.
Just got back from a 40min drive one way and another 40min back and drove perfect. I did swap a NTK tps sensor but I don’t think it had much effect as the first drive it acted up on the long drive back yesterday.
