Coad P1757
Old Aug 24, 2022 | 10:42 AM
Handymankiley's Avatar
Handymankiley
Default Code P1757
My 99 Ram 1500 is throwing a P1757 DODGE Code - Governor Pressure Above 3 psi at 0 MPH and not shifting from 1st.. when it is cold is shifts fine but as soon as it warms it is stuck in high gear. I replaced both governor sensor and solenoid and had no change what so ever. Anybody know what solenoid I shoud replace next ?
Old Aug 24, 2022 | 07:33 PM
There aren't any left that would have anything to do with your problem.....
Take it to a trans shop.
Old Aug 24, 2022 | 09:14 PM
95RAM360's Avatar
95RAM360
Unless the wiring itself is damaged
Old Aug 24, 2022 | 09:25 PM
True that. One member hand exposed copper at the trans connector... got all sorts of odd behavior.
Old Feb 20, 2023 | 10:34 AM
Darren Davis's Avatar
Darren Davis
I'm having the same exact issue with my 98 5.9 1500 automatic... But, I have new torque converter, trans fluid temp sensor and governor solenoids. I don't have any codes popping up now but it's still having this issue of shifting fine when cold but failing when warm along with a hissing sound when I let off the gas at high speeds, and when I'm at a read light it takes a bit gettin to speed as if I accelerated on 2nd gear.
