5.9 rebuild list
Old Sep 6, 2022 | 11:10 AM
mikemerrill50's Avatar
mikemerrill50
You cam should have a spec sheet for what proper valve pressures ought to be. Could also call the manufacturer, and see what they have to say. (keeping in mind, that they would just LOVE to sell you valve springs/locks/keepers as well.....
The springs in the EQ monster magnum heads should be enough for the cam specs, and according to everything I've read. I was just responding to Moparite's comment that I'd need better valve springs. I just want to make sure I'm not missing something.
Old Sep 7, 2022 | 05:47 AM
Moparite's Avatar
Moparite
If you look the cam up on comps web site it says needs different springs. It should tell you with any documentation that came with it.
Old Sep 7, 2022 | 09:53 AM
mikemerrill50
The EQ monster magnum heads come with
valve spring 125# seat 315# open @ .575 lift max
Which should be enough
Old Sep 7, 2022 | 02:08 PM
Adobedude's Avatar
Adobedude
Originally Posted by mikemerrill50
did you have any issues with the intake manifold bolting up properly after shaving the heads?
I may get smaller CC heads anyways
I didn't have a problem but I also use RTV on the China wall, I don't like the end gaskets.
Lots of misinformation by manufactures out there, Eddy says their heads are 58cc, that's what mine are after milling them .030.
