V10 stalling issues
Old Sep 5, 2022 | 05:06 PM
2genV10's Avatar
2genV10
The elbow on the throttle body looks good no cracks or leaks. Key on engine off Map reads 29 (inHg) while at idle it's at 10 (inHg). If I rev the engine it drops to 7-8 (inHg).
Old Sep 5, 2022 | 06:03 PM
Ok, that actually sounds fairly correct..... Curious what it compares to that makes it think it's too high..... (voltage)
Old Sep 6, 2022 | 07:58 AM
69_XS29L's Avatar
69_XS29L
MAP sensor screws directly into the intake above the throttle body. There is no plumbing for obvious reasons. That elbow is part of the vapor purge. Should be fed the same 5 volts the TPS gets. Short of just throwing a new sensor on you'll need a voltmeter and the factory 'Powertrain Diagnostics' manual which defaults to Chrysler tech scanner use, but has a lot of useful information,or perhaps somebody with experience to help.
Air temp sensor is the one down low behind A/C compressor.
Old Sep 6, 2022 | 04:33 PM
2genV10's Avatar
2genV10
Very informative thanks ! Now is it a constant 5v or just with the key on?
Old Sep 6, 2022 | 05:10 PM
Should only see 5 volt feed with key on.
Old Sep 6, 2022 | 05:18 PM
2genV10's Avatar
2genV10
Ok gotcha
Old Sep 8, 2022 | 10:15 PM
2genV10's Avatar
2genV10
Originally Posted by 2genV10
Ok gotcha
Ok I just put the new map sensor in and I am getting 5v with the key on. So let's see what happens tomorrow 🤷
I'll keep everyone updated. Thanks for all the help!
Old Sep 17, 2022 | 01:16 PM
2genV10's Avatar
2genV10
So far so good guys! Hasn't stalled or cut off yet. Thanks again for your help I really appreciate it 👍
