high idle on 5.2L 1500
Old Jan 5, 2006 | 01:15 PM
clutchn's Avatar
clutchn
Default RE: high idle on 5.2L 1500
cleaned the T/B and IAC with carb cleaner, and still idles high. the plunger on the IAC, goes up and down very smoothly after cleaning. no vacuum leaks.
Old Jan 6, 2006 | 11:54 PM
clutchn's Avatar
clutchn
had a friend scan it today, and it came up P1294. did some searching on the net, and it looks like it's either a vacuum leak, or an injector. i dont hear any vacuum leaks, and ive sprayed every vacuum hose i can find with carb cleaner. there was never a change in idle.
BTW, the truck idles at about 1,400 rpms, and is running lean. only thing ive done to the truck is added a 14"x2" open air cleaner.
how can i find out if it's an injector issue?
Old Jan 7, 2006 | 01:31 AM
Koldkut's Avatar
Koldkut
IMO, high idle is a problem of too much unregulated air getting into the engine. so I think you have something loose that shouldn't be. I'd check all your intake bolts. Hit them with a torque wrench to make sure they are good, same with the throttle body bolts. I had a loose intake on my jeep and one quarter turn of an intake bolt fixed my high idle......it was that simple...
Old Jan 7, 2006 | 02:00 AM
clutchn's Avatar
clutchn
ORIGINAL: Koldkut
ill give it a shot. have to use some compressed air to blow all the dirt and leaves off 1st. [sm=bling.gif]
Old Jan 8, 2006 | 02:28 PM
clutchn's Avatar
clutchn
well, today i re-torqued the intake, and put in a set 19# injectors. still idles high, but not as high. i did notice that the hose that comes off the driver side valve cover, pulls a lot of vacuum at idle. like i said earlier, i have a open element 14" air cleaner on the truck. i have that hose hooked up on the bottom side of the air cleaner. i did block it off with my thumb, and the idle dropped down a little bit.
ill drive it around some more to see if the CEL comes back on. (i disconnected the neg. cable, to reset the light.)
Old Oct 25, 2006 | 03:42 PM
steelerguy's Avatar
steelerguy
What fixed this?
Old Oct 25, 2006 | 03:59 PM
clutchn's Avatar
clutchn
ORIGINAL: steelerguy
What fixed this?
belly pan gasket
i ordered that billet aluminum plate from ASP along with new hardware and a revised gasket. its been months now, and i havent had a problem.
Old Oct 25, 2006 | 04:15 PM
steelerguy's Avatar
steelerguy
ORIGINAL: clutchn
What fixed this?
belly pan gasket
Got me scratchin' on this??? Don't see any references to "billet aluminum plate from ASP along with new hardware and a revised gasket" in this thread. Where axactly are they? What is ASP?
Thanks for the help.
Old Oct 25, 2006 | 07:52 PM
clutchn's Avatar
clutchn
sorry, it's APS not asp.
http://www.apsprecision.com/billetplenum.html
Old Oct 25, 2006 | 08:04 PM
timwag2001's Avatar
timwag2001
http://www.hughesengines.com/partDet...698&eTypeID=10
