No Reverse lights
Old Nov 2, 2022 | 11:10 AM
WrenchingtheWretched's Avatar
Default No Reverse lights
So on my 99 1500 5 speed I don’t have any reverse lights. New bulbs, good fuse, clean bulb connection. Where should I look next? I’ve searched the entire harness for a bad ground etc.
Old Nov 2, 2022 | 11:23 AM
crazzywolfie's Avatar
crazzywolfie
i would recommend checking out the backup light switch on the transmission. connecting the 2 wires at the transmission should make the lights come on if everything is working as it should. if not measure to see if there is power at the switch. also make sure you are checking these things with the key in the run position since it likely doesn't get power with the key in the off position.
Old Nov 18, 2022 | 06:11 AM
Originally Posted by Bisdhim
It's up to smart and dedicated guys like you to make it work. It's not fair, but it is necessary given the poor quality of parts these days.
I second that. I find it crazy that a few years ago when I was working on my 91 K1500 replacing the distributor module I had to go to the parts store 3 times to get one that actually functioned. Wild that NEW parts are defective. QC doesn’t exist anymore.
Old Nov 18, 2022 | 03:20 PM
Kentucky Fried Redneck's Avatar
Be sure to check out the wiring inside the steering column. I just had a similar issue with my wife's truck. Turns out something is loose in the steering column when you wiggle the gear shift a little the lights come on, then you barely touch it, or let the truck move and they go out. I haven't had the chance to deep dive the issue yet, but it's definitely in the steering column.
Old Nov 18, 2022 | 03:21 PM
mine is a manual
Old Nov 18, 2022 | 03:43 PM
Originally Posted by WrenchingtheWretched
mine is a manual
Ah, damn, ok. nevermind then lol
