Codes
Old Nov 8, 2022 | 06:13 PM
Donnygee's Avatar
Donnygee
Default Codes
Needing advice,
I am trying to start my 1995 Dodge Ram 1500 5.2 manual transmission. The engine cranks but no spark. I used a code reader and got codes 11 & 24. I then replaced the crankshaft sensor, throttle position sensor, pickup coil, ignition coil and distributor cap and rotor. Truck still wont start, what to do now?
Don
Old Nov 8, 2022 | 06:42 PM
Are you getting spark? Does the fuel pump run when you turn the key on?
Old Nov 9, 2022 | 05:37 PM
Donnygee's Avatar
Donnygee
I am not getting spark and I am getting fuel through the fuel rail. One thing the code also says is that I am getting high voltage to the TPS.
Don
Old Nov 9, 2022 | 06:25 PM
Verify what the TPS is getting. Got a volt meter?
Old Nov 9, 2022 | 08:27 PM
crazzywolfie's Avatar
crazzywolfie
what type of crank position sensor did you use? it is usually recommend to get the mopar one. if you went aftermarket it could be part of your issue. i would also test for power at the coil plug and test for ground at the coil plug while cranking. the TPS should not prevent you from having spark.
