Read thru the procedures a few times, to get an idea of what you are up against, then, be REALLY organized about disassembly..... keep everything in order, makes putting the jigsaw puzzle back together a lot easier.
All the bearings (or at least the ones that show wear), as they might gotten damaged by the metal particles broken off from the gears. Naturaly all the broken gears needs to be replaced, and check thoroughly syncro parts.
After I read over the Manuel and go threw the gears I'll post some more photos alot of the internal components I'm not sure of the names associated with them
