Wiper issues
Old Dec 19, 2022 | 05:26 PM
KillerLemming's Avatar
KillerLemming
Default Wiper issues
Hello, I have a 2002 Ram 2500 and the wipers are having issues where it only has three speeds, when you set it for the first one it goes constantly (like the 3rd to last speed) and when i switch it for the next few positions it stays the same until the last 2 settings, it will also stop in whatever position it is turned off at. When I use the washer spray it does a few passes but than stops. I'm assuming this is the wiper motor but could anyone guide me in the right direction? Thank you!
Old Dec 20, 2022 | 06:41 AM
WrenchingtheWretched's Avatar
I would try the multifunction switch first.
Old Dec 21, 2022 | 11:07 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The stopping wherever they are is normal. They don't push when they lose power as you are suppose to put them upright to change the blade. The washer fluid action seems to be normal to. I second checking the multifunctional switch
Old Dec 21, 2022 | 03:13 PM
KillerLemming
I should have phrased it better as the washer action isn't normal. It used to go back to the bottom of the windshield after spraying but now it stops at random points i have to turn on the regular wipers to get it back to the "home" position. I attached a pic of where it stopped when using the washer fluid, It never stopped here until recently.
Old Dec 24, 2022 | 12:10 AM
MoparFanatic21
That's tough my gut says multifunctional switch but it could also be the motor
Old Dec 24, 2022 | 03:42 AM
HeikIlm's Avatar
HeikIlm
I had a bad motor which acted like that, eventually it failed to work in a heavy rain. Pulled motor apart, and it was unsaveable. Full of rust.
Old Dec 24, 2022 | 09:58 AM
Moparite's Avatar
Moparite
There is a switch in the motor assembly, The module will give it power to return to the home position. I would check the return signal coming from the switch to the module. If that's not the issue the module is.
