98 1500 5.9 quad cab run issue?
Old Dec 23, 2022 | 09:14 PM
Beartracker981500's Avatar
Beartracker981500
Default 98 1500 5.9 quad cab run issue?
so I replaced cap rotor, sparkplugs and wires . Cleaned the throttle body and the air idle control
new cam sensor new crank sensor, started it and it ran great...for about two days now it is missing at lower rpm's.
give it some throttle and it straightens out until it shifts into high and the rpm's drop and were missing again
no codes. Any suggestions?
Old Dec 23, 2022 | 09:48 PM
Disconnect the front O2 sensor, see if it changes anything. (both, if you have two front sensors)
Old Dec 24, 2022 | 01:16 AM
Beartracker981500
I will try that, I was also wondering if it could be something like the EGR system
Old Dec 24, 2022 | 10:09 AM
Moparite's Avatar
Moparite
98 doesn't have an egr, Did you double check the wires that they are on both the plugs and cap securely? If it's amiss at idle you can pull the wires off one by one to find what cylinder it is. Definitely helps to put some dielectric grease on the boots to help with installing and removing.
Old Dec 24, 2022 | 02:45 PM
Beartracker981500
thanks for the idea and I already checked all that ,
now its throwing a code for the output sensor on the transmission I am not a transmission person other than swapping them out
will the speed sensor cause this
Old Dec 24, 2022 | 02:56 PM
No, speed sensor won't affect how the engine runs.
