2014 rims on a 99?
Old Dec 30, 2022 | 02:52 PM
jryhaugan4221's Avatar
jryhaugan4221
Default 2014 rims on a 99?
Anyone ever try this move before? I like the look but wondering if anyone has ran into problems with it? Thank you all
Also if anyone would like the old ones please let me know. Free of charge unless your a Ohio State Fan
Old Dec 31, 2022 | 09:59 AM
Moparite's Avatar
Moparite
Don't know what year but i think they started using bulge acorn style nuts.
Old Dec 31, 2022 | 11:52 AM
jryhaugan4221
bought all new nuts and seem to fit great…. For now hahah but got 5 rims N tires for $300 so I pray to the good lord above they hold up.
any advice on try to get a spark plug out? I’ve got two more that seem to keep getting tighter as I loosen them
Old Dec 31, 2022 | 12:08 PM
Work the plugs back and forth, also helps to have the engine a little warm. Chemicals can also be your friend. PB Blaster works good for me.
Old Dec 31, 2022 | 02:27 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
If you have access to compressed air, be sure to blow the trapped debris from around the spark plug, then liberally douse it with PB Blaster. It's also preferable to remove those pesky metal spark plug tubes from around each spark plug to keep debris from collecting and causing the issue you're experiencing. Those metal spark plug tubes are useless and can be thrown away, as they do more harm than good..
