Another "No Bus" thread
Old Jan 2, 2023 | 04:43 PM
pnutbutter's Avatar
pnutbutter
Angry Another "No Bus" thread
Hi all,
I am sorry to start another thread about the stupid "no bus" issue, but I think I may be missing some steps in my diagnostics.
I have a 01 2500 CTD Auto 4x4 QCSB that had a transmission fail. The truck was running fine, and we decided to swap in a good donor trans from the exact same truck with 70K miles and no rust. Since the transmission was installed, I am getting the "no bus" code on the dash, and the typical crank-no-start, no dash gauges, lights on, etc.
In research, I did the following to diagnose:
- Check, clean, and grease connections C1, C2, and C3 at the PCM and the main connector on the PDC
- Check for codes, my code reader will not connect
- Look for broken wires, things that may not be plugged in, chewed wires, etc. - all good
- Measure resistance at pin 31 of the C1 connector, resistance was too high - repaired wire and ohm reading is now within spec
- Individually unplug all connectors C1-C3
- Unplug new trans
- Disconnect and reconnect battery after all of this, even replaced battery as the old one was dead
And I am still getting the code. Is there anything else I can check before just grabbing another computer? I find it hard to believe the computer died as it ran before the trans was in. Any help is appreciated!
TIA
Old Jan 2, 2023 | 05:10 PM
Did you pinch some wires between the engine and trans?
Old Jan 2, 2023 | 05:14 PM
pnutbutter's Avatar
pnutbutter
I did not do the transmission install, it was handed off to my cousin that has access to a dealership shop. I did, though, get under and look with a flashlight and a mirror and did not see any pinched wires
Old Jan 2, 2023 | 05:15 PM
The no bus error is a major pain to troubleshoot, too many possible causes..... Might try unplugging sensor, one at a time, and see which one (if any...) make the problem go away.
Old Jan 2, 2023 | 08:03 PM
Beartracker981500's Avatar
Beartracker981500
check all of your grounds
