Timing cover
Old Jan 10, 2023 | 11:12 PM
tylet's Avatar
tylet
Default Timing cover
Need to replace timing cover gasket removed all the bolts or at least I think I have timing cover won’t budge any ideas thanks 1998 Dodge Ram 1500 5.9 360
Old Jan 11, 2023 | 01:01 AM
Keith_L's Avatar
Keith_L
I've got some pics here, although in this thread I deliberately left the wp attached (4 of the wp bolts run through and anchor the cover)
There are also a couple vertical oil pan bolts you have to pull.
See:
https://dodgeforum.com/forum/2nd-gen...-and-wp-2.html
Old Jan 11, 2023 | 10:38 AM
ol' grouch's Avatar
ol' grouch
Silly question, but you removed the water pump and harmonic balancer didn't you? Like Keith L said, there are a couple of bolts underneath on the oil pan. They can be stuck on there pretty good at times.
I'd look for slop in the timing chain while I was in there. You've already done most of the work so I'd replace it if it has quite a few miles on it, Now, if you just replaced it and the cover is leaking.......
Old Jan 11, 2023 | 10:04 PM
AtomicDog's Avatar
AtomicDog
And please, replace the timing chain and gear set with a good double roller timing chain and gear set. If your existing timing chain and gears haven't been done before, you will typically recoup some lost engine power with the restoration of accurate timing of the engine.
Old Jan 12, 2023 | 09:32 AM
This. Replacing the timing set was one of THE best things I did for my truck.
