Anyone replaced the factory 3rd brake light with an alternative? If so, what?
Old Jan 31, 2023 | 03:34 PM
AtomicDog's Avatar
AtomicDog
Question Anyone replaced the factory 3rd brake light with an alternative? If so, what?
My original 2nd gen third brake light looks old and faded, so I'm thinking about replacing it. Has anyone replaced theirs with something other than an original 2nd gen third brake light? If so, what did you use (photos of the replacement are helpful), was it more or less plug and play and are you still happy with it?
Old Jan 31, 2023 | 05:45 PM
Spillage's Avatar
Spillage
I got an LED one from Amazon several years back… less than $30.
Plug-n-play.
I set it in a thin bead of silicon to make sure it didn’t leak.
Still works and looks fine.
Old Jan 31, 2023 | 06:49 PM
AtomicDog's Avatar
AtomicDog
Nice and thanks! Anyone else?
Old Feb 1, 2023 | 12:26 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
If it's fading, run a headlight restorer on it and I put in bright LED's.
Old Feb 1, 2023 | 01:03 PM
AtomicDog's Avatar
AtomicDog
Talking
Thanks for the thoughts. Those were my 1st thoughts as well, however, I wondered what others may be doing or have used to replace their factory light setup. Yes, mine is definitely fading after all of these years.
Old Feb 2, 2023 | 11:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I put a chrome one in but had to be modified. The cargo lights stayed on. I can show you what needs to be done if you want. They make them as a switched ground where ours are switched power.
Old Feb 2, 2023 | 11:38 PM
AtomicDog's Avatar
AtomicDog
Thanks. Does anyone know if a 3rd gen 3rd brake light can work on a 2nd gen truck?
