42RE ran low on tyranny fluid - see post
Old Feb 6, 2023 | 12:14 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
The 42RH went behind the V6. Transmission Bench has a video for easy rebuilding of your transmission. It is a step by step process and if you can turn a wrench, Yes, you can rebuild your transmission. Watch the whole series before you dive into this
And a inexpensive rebuild kit 518, 46RH 46RE Transmission Overhaul Kit With Steels & Both Bands 90-97 | eBay
Old Feb 6, 2023 | 01:41 PM
rrb6699's Avatar
rrb6699
Originally Posted by PR1AWRet
The 42RH went behind the V6. Transmission Bench has a video for easy rebuilding of your transmission. It is a step by step process and if you can turn a wrench, Yes, you can rebuild your transmission. Watch the whole series before you dive into this https://www.youtube.com/watch?v=3J1ErheBwHE And a inexpensive rebuild kit 518, 46RH 46RE Transmission Overhaul Kit With Steels & Both Bands 90-97 | eBay
I'll look over the video. not sure if I will have the time to mess with it. that's my only concern. but I doubt I can get much $$ for it current condition and it would be good to go if I rebuilt the tyranny.
rr
Old Feb 6, 2023 | 02:20 PM
AtomicDog's Avatar
AtomicDog
Did you ever determine if you have a 42RE or 42RH transmission in your truck? If it's a '96 truck, it should have a 42RE, but you should also have a OBD2 connector under the dash as well...
Old Feb 6, 2023 | 02:23 PM
AtomicDog's Avatar
AtomicDog
Post
I thought the same thing, but after researching it a bit, seems that some of the early 2nd gen light duty trucks with 5.2 engines in them also got a 42RE transmission.
Old Feb 6, 2023 | 03:50 PM
If it got a light duty trans, it should be the 44R? behind a V-8. 42 should only have come behind the six. Wonder if your trans was changed earlier in the trucks life....
Old Feb 6, 2023 | 07:35 PM
AtomicDog's Avatar
AtomicDog
Post
This is one place that talks about the 42RE being used in light duty Ram 1500 trucks with a 5.2 engine or the V-6 engine..
https://itstillruns.com/differences-...s-8734382.html
It would be very helpful for the original poster to double-check to determine exactly what transmission is in his truck.
Old Feb 6, 2023 | 09:42 PM
Wow, that looks like a good revenue stream for the trans guys at the dealership.......
Maybe pull a build sheet? That would tell him what came stock at least.
Old Feb 6, 2023 | 09:58 PM
AtomicDog's Avatar
AtomicDog
Angry
Absolutely! Seems that there were several transmission complaints associated with that configuration. Reminds me of a friend of mine that had a mid 80's Ram 1/2 ton truck with a 318 engine and a 904 transmission. He ended up selling the truck before the 904 transmission gave up the ghost.
Old Feb 7, 2023 | 12:21 AM
rrb6699's Avatar
rrb6699
that's the odd thing about this. I have a analog speedometer odometer all mechanical none of that's electronic. Check engine light is on but as I recall it was for two seemingly non-related issues which I addressed but it still didn't get rid of it. Now there might be a plug under there but it does not fit an OBD-2 as I recall trying that reader plug, so, I just figured it was an OBD plug, but, at least I can still Flash the codes with the key by counting the flashes until I get end of code signal.
Last edited by rrb6699; Feb 25, 2023 at 08:58 PM. Reason: sp, talk text corrections
Old Feb 7, 2023 | 01:06 AM
AtomicDog's Avatar
AtomicDog
It should be an OBD2 plug on a 1996 truck. Got a photo of the plug in the truck? You can also try flipping the OBD2 scanner plug upside down and inserting it into the connector to see it it fits. Lastly, do you have a build sheet under the hood of the truck?
