How to set clock
Old Jan 4, 2006 | 05:36 PM
RAMbunkshus's Avatar
RAMbunkshus
Default How to set clock
I hope this isn't a dumb question, but can someone tell me how to set the clock function on my '97 Ram's audio system. It's a factory single CD system. There's a rocker that's labeled H(our)/M(inute), but it seems that another button or two must be pressed to set the clock. I purchased the truck used, and don't have the factory manual, so any help will be much appreciated.
John in SW Ohio
Old Jan 4, 2006 | 06:40 PM
ebxgsxr's Avatar
ebxgsxr
Default RE: How to set clock
should be 2 very small buttons. i used my knife to adjust the time. maybe a pen tip or pin will also work.
Old Jan 5, 2006 | 03:50 AM
delvo85's Avatar
delvo85
all you do is get a pen or a toothpick and press on the lil buttons that are pushed in to adjust the time...
Old Jan 5, 2006 | 09:41 PM
Racinfan83's Avatar
Racinfan83
ORIGINAL: delvo85
What he said......one more tip - I have to push the button twice to get the numbers to start moving
Old Jan 6, 2006 | 05:27 PM
RAMbunkshus
Thanks, guys. My clock is now showing the correct time. I never noticed the little holes for setting the clock, since the H(our) and M(inute) legends were next to the rocker switch, I assumed that the rocker was used to set the time. Thanks again for the good info.
John in SW Ohio
