Donor Truck
Old Feb 10, 2023 | 12:56 AM
Xombi's Avatar
Xombi
Default Donor Truck
I have a 01 Ram 2500 2 WD 5.9 v8 I would like to put a MT in. I can purchase a 97 4wd 1500 with a 360. I though I read that 1500 360's had the NV 4500 behind it.
Do I need a 2wd trans for the swap.?
Old Feb 10, 2023 | 02:54 AM
HeikIlm's Avatar
HeikIlm
Yes, you'll need a 2wd trans. Though you could swap the output shaft to the 4wd trans, and also need to get a 2wd tail housing.
Old Feb 10, 2023 | 08:47 AM
Xombi's Avatar
Xombi
Would it be the NV3500 or 4500 transmission because of the 360?
Old Feb 10, 2023 | 08:58 AM
Manual trans never came behind a 360 in a 1500. The lighter duty trucks got the 318. I suspect that one has been swapped in.
Have a look at the trans, if the bell housing is part of the trans case, NV3500. If it bolts on, NV4500.
Old Feb 10, 2023 | 10:19 AM
Xombi's Avatar
Xombi
Thumbs up Auction description wrong.
Auction description was wrong. They saw a transfer case lever on the floor. Thanks. 3B7HF13Z4VG779021. Heads up to forum members who are looking for a donor 4wd truck near D.C. Thanks.
