Rad leak
Old Feb 13, 2023 | 11:14 PM
96albertaram's Avatar
96albertaram
Default Rad leak
So I’ve been noticing drips come from the spout at the bottom of my rad. The drain plug is dead tight . How does this even happen? Anyone ever experience this . Is this normal ??
Old Feb 13, 2023 | 11:45 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
If it's a factory clamp, try replacing it with a worm clamp and tighten it enough to see if the leak stops. If the lower radiator hose is old, it could be soft and need to be replaced. The radiators do expire after a while - the newset 2nd gen trucks are 20+ years old. They typically leak around the plastic tanks that are crimped/sealed onto the aluminum core. Personally, I replaced my radiator with an all-aluminum radiator to try to avoid that issue. Some folks enjoy getting a factory style replacement radiator (plastic tanks + aluminum core) with a lifetime warranty, if a radiator is needed. Your choice..
Old Feb 14, 2023 | 06:20 AM
Moparite's Avatar
Moparite
Remove the drain plug and see if any debris is in it or the o ring is bad.
Old Feb 14, 2023 | 08:13 AM
96albertaram
it’s not leaking below the drain plug it’s leaking at the spout beside it . I tried getting a pic with a drip coming from it but some times it takes awhile
Old Feb 14, 2023 | 09:19 AM
Keith_L's Avatar
Keith_L
I can't say I specifically recall using an OEM petcock on a 2nd Gen but the few I've handled often have o-rings. It's conceivable an o-ring dried out or split.
Many mechanics don't touch the petcock as a matter of SOP because they seize up and then snap. I learned the hard way (on other makes) and no longer risk it, esp on customers' vehicles. I just pull the lower rad hose if possible if I need to drain a cooling system.
POINT BEING, see if you can source an entire replacement before you disturb it. As much as it pains me, Dorman often sells replacements because of the fact the plastic ones break so often. My local Autozone stocked the Dorman/HELP! for an '05 Escape.
Old Feb 14, 2023 | 09:23 AM
Keith_L's Avatar
Keith_L
Yep
Old Feb 14, 2023 | 10:19 AM
That spout is where the coolant drains when you open the petcock.....
Old Feb 14, 2023 | 10:27 AM
96albertaram
ya I’m.not a fan of that pet ****. But if the o ring is failed how come it’s leaking on the side of that spout instead of the bottom of the petcock?
I wanted to change this rad out for an aluminum one but apparently they are non existent now such a shame
Old Feb 14, 2023 | 11:11 AM
AtomicDog's Avatar
AtomicDog
The all-aluminum radiators for the 2nd gen Ram still exist. Check eBay & Google. While the SCF 2969 all-aluminum radiator is no longer available, there are plenty of other options available.
Old Feb 14, 2023 | 11:35 AM
Keith_L's Avatar
Keith_L
If it's leaking on the side it's either coming from above or the plastic is cracked around the spout
