Loud Rumble at 65mph and 1900rmp
broken wires in the steering column? So take the dash apart probably to get that all apart?
Grab a service manual for your truck from here, if you don't already have one. Wiring diagrams are in section 8W. (I think in the trans control sub-section.) That will tell you what color wires, and where the connector for them is. Once you find the connector, unplug it, start the truck, and short the two pins together for a second. See if O/D Off lite comes on. If it does, problem is on the other side of the equation.... Unfortunately, I think that means replacing the shift lever...... not sure you can change JUST the switch.
Button is on the end of the shifter ****, right?
I know you really want it to be your transmission but it's difficult for an auto to make the noise you describe.
Autos are essentially hydraulic propulsion so typically you'll get no shifting, poor shifting, shift flares or even bucking/shuddering....but a speed dependent grumble is really unlikely. Obviously it's not impossible -- I mean it's also possible I'll be abducted by aliens in the next 5 minutes.
Can you plug the rear slip shaft and get it up to speed on the front d/s only?
Your problem still says harmonics to me like from incorrect pinion angle or out-of-balance rear d/s or something similar. Your transmission mount is ok? How about engine mounts?
If you know the mount is tired I would change it not so much expecting it to cure the problem but to assure you're starting close to baseline. I mean you can't tell if someone maybe has genetically high blood pressure if they also smoke a pack a day and eat junk food non-stop.
I would NOT do poly ANYTHING until after you've solved this. OEMs use rubber because of its favorable NVH characteristics. If you add poly bushings anywhere you're only muddying the water.
A sagging trans mount will change driveline angles so it could cause your symptoms. In truth the total change in degrees is pretty minor, but if the rubber is REALLY dilapidated you could have metal on metal within the mount.
ok so new rubber trans mount. It’s like $40. Not a bad thing to do even if it doesn’t cure the problem. I just really want to get this fixed. But guessing and guessing on the problem is very hard cause I can’t tell exactly where the sound is coming from. Only way to get it to make the noise is on the open road at 60mph and at that speed it’s so hard to tell exactly where noise is coming from. The pickup doesn’t make the noise when it’s up on blocks in the shop. Runs and sounds smooth.
brand new ones on front, back ones are older but decent.
Loose bands usually just slip.
